Crash on import – program error -2014
A few months ago we switched to the Media100 Suite 1.1.1 and everything has been running great until now. We purchased an XDCAM EX PMW-350, using the SxS cards. The media100 keeps crashing with this code (https://www.visualmktg.com/m100/crashss.png) on importing of certain clips.
Here is the workflow:
Using the clip browser (CRC check on) copied the contents of the SxS card to a hard drive (also to a mirrored drive for source footage backup). Launching the Sony Transfer software from within Media100, the selected clips are imported using the Apple ProRes 422 codec. Media100 crashes on certain clips. When I find the re-wrapped quicktimes in Finder, quicktime plays these clips fine. They also import just fine into FCP. (My workaround has been to import these possibly “corrupted” clips into FCP then export them with the ProRes codec, then import into M100. This works fine but takes a bit of time.)
I have since then installed the 7.1 AJA driver, along with M100 v1.1.3. The results are the same. Same crashes on the same clips. The error I am getting from what I have read is a Quicktime (file duration) error. Not sure what that really means. I was thinking that perhaps the SxS card is corrupt, but the clips all come in fine into FCP, and are exported, then imported into M100 without problems. So I am not sure what’s going on. Any ideas?
-RH
