Activity › Forums › Apple Final Cut Pro Legacy › Crash may be cause by KGCore plug-in???
Joshua Preiswerk replied 13 years, 4 months ago 29 Members · 42 Replies
Gerrit Van woudenberg
October 6, 2010 at 4:08 am[Diego Piro] “Doesn’t matter if FCP crashes when opening FCP or when opening a project. If you get the KGcore plug-in crash just go to where you are saving your thumbnail data and erase the contect of the folder. That is it.
The data will be recreated when you open the project.”I’ve been having this problem for 4-5 days now, and this solution did NOT fix the problem.
My Final Cut’s been crashing just after the ‘offline files’ dialogue box while finishing loading the project. From where I would get the clock cursor thing for a second and then the spinning wheel of death for 5 minutes and then crash. After trying this fix, it probably took 1 minute before the cursor flipped to spinning wheel of death, but that’s about it. Still froze for a while then properly crashed after 5 minutes.
Derek Fremd
February 1, 2011 at 4:45 amI have been having these crashes of late and found the culprit. I discovered that a couple of sequences my co-editor was working on had some alpha transitions. Upon transferring the FCP projects to my drive, the well drops in the alpha transitions emptied. When I tried to render the project FCP repeatedly crashed. When I noticed the alpha transitions were empty I dropped in the requisite clips, alpha, etc. Thereafter, the sequences rendered without incident and I have no longer had the KGCore crashes.
Erkka Varvio
February 18, 2011 at 12:33 pm[Diego Piro] “Hello People, after much research and reading all your posts. I found the solution.
The data will be recreated when you open the project.Let me know if it worked for you.”
Missed quote earlier, sorry… This was the solution for me, thanks Diego!
Mart Berl
March 23, 2011 at 10:23 pmHi !
In my case I found this related to one media (avi) waveform. When its switched off in timeline nothing hangs. So, I erased Waveform cache for this file and Bingo! FCP redrew it, and everything works!Mart
Patricia Van der does
July 20, 2011 at 8:16 am‘where you are saving your thumbnail data and erase the contect of the folder’
I have the same KGCore crash but where can I find this thumbnail data?
thxs -
Jeremy Garchow
July 20, 2011 at 1:31 pm[Patricia van der Does] “where can I find this thumbnail data?”
In the FCP Docs folder of your scratch drive
