Activity Forums VEGAS Pro Crappy audio
  • Crappy audio
    Posted by Morty Aronsen on November 13, 2009 at 3:42 pm
    Hi!
    I have rendred my project with DVD Architect PAL video stream.. The footage is quite good, but I included the audio (checked the box under audio), and as far as I can see that makes dvd architect compress my audio.. The audio is boxy and awfull.. What should I render my audio as, to avoid compression in dvda? Hope yuo can help me out.
    M
    Terry Esslinger replied 16 years, 10 months ago 3 Members · 6 Replies
  • Theo Van laar
    November 13, 2009 at 3:51 pm
    What most people do is render the video in Vegas as MPEG2 and render the audio also in Vegas as AC3 as a separate file. In DVDA you just import the MPEG2 file and the AC3 file will follow automaticly (if you had given it the same name and stored it in the same folder). DVDA will not recompress AC3 files.
    Theo
  • Morty Aronsen
    November 13, 2009 at 4:17 pm
    Ohhh.. Thank you, that make sense.. Love it, when the answer is so easy, and so rapid (-:
  • Theo Van laar
    November 13, 2009 at 4:19 pm
    OK, success!
    Theo
  • Morty Aronsen
    November 13, 2009 at 4:24 pm
    By the way, should I change some of the default settings?
  • Theo Van laar
    November 13, 2009 at 4:26 pm
    For the audio? No
    Theo
  • Terry Esslinger
    November 13, 2009 at 6:17 pm
    Actually its recommended that when you bring up the render as menu and choose AC3 that you then choose custom and in the audio service tab you cange the Dialogue Normalization to -31 (from -27) and on the preprocessing tab tab change the line mode profile and the RF mode profile to none.
    I have made this a new template and named it DVD so that I don’t have to make the changes every time.
