Activity Forums Boris FX Particle Illusion COW Tutorials: particleIllusion Disintegrating People and Other Things
  • Fizz
    July 31, 2005 at 9:44 pm
    Nice tute, should satisify a lot of people who post here!!
    Well done Elvis:-)
  • Dotan Baytman
    August 1, 2005 at 12:43 pm
    HI
    yes great tutorial and answer alot of questions
    thanx for sharing that
  • Mastar
    August 4, 2005 at 11:39 pm
    I have made the tutorial and made it several times, but it seems that i missing i few thing to get te right looks. Could someone look at my file.
    https://s48.yousendit.com/d.aspx?id=2ZP73BGAGVZ0B36JUDKCG9CXM8
    Thanks in advance.
  • Mastar
    August 8, 2005 at 10:33 am
    Are there other people that have problems with following the tutorial?
  • Elvis Deane
    August 8, 2005 at 7:20 pm
    I couldn’t open up your file the first two times I downloaded it, seems to work now though.
    The key thing you seem to be missing is that you haven’t hidden the background image on frame 58 by following the steps in the second paragraph. Other than that, all you really need is to add a lot more particles and play around with the Weight, Velocity and Motion Randomness so that the particles scatter nicely.
    Elvis Deane!
    The particleIllusion FAQ
    particleIllusion Resources and tutorial CD
    Astounding Adventures
  • Ktpmm5
    August 14, 2005 at 4:33 pm
    I’m having probs with this tut, but mostly because I’m a complete newbie to this, so pardon my questions. When I bring in the background image on a new layer, I uncheck the Hold Last Frame box. However, there is no “End” box under Sequence/AVI. Just a “Start Project at Frame X” box. I’m assuming that I imported the file incorrectly (It’s bg.png).
    Thanks for any help
  • Keith Evans
    March 10, 2009 at 10:03 pm
    I’m also missing the start and end fields in the Background Image property box. There are a start/end fields to fill in for sequence or avi in the tutorial image. Anyone know why the end field is not there?
  • Alan Lorence
    March 11, 2009 at 4:27 pm
    You’re using an old version of the software I think.
    Alan.
    http://www.wondertouch.com
