COW Tutorials: Final Cut Pro Really? Capture HDV to ProRes in FCP? Over FireWire?! Yes!
One of the feautres that snuck into the new edition of Final Cut Studio is that you can now capture HDV directly to ProRes over FireWire! There are a couple of issues you’ll want to consider, but Chris Poisson, a Cow member since 2001, takes you step by step through a process that can make a big difference to the way you edit HDV in Final Cut Pro from now on.
Click on the link above to find Chris’ article.
Kathlyn Lindeboom
Mistress of Mmmooooo
