Activity Forums Adobe After Effects Expressions COW Tutorials: After Effects Building and Animating a CG Snake
  • COW Tutorials: After Effects Building and Animating a CG Snake
    Posted by Kathlyn Lindeboom on July 29, 2007 at 10:51 pm
    In this video tutorial, Jerzy Drozda Jr (aka Maltaannon) demonstrates how to create a dynamic animation based on a ‘chain rig’. You’ll learn how to animate one layer using keyframes, expressions, or both, and make other layers follow the leading layer. The rest of the tutorial is about texturing and making the final look.
    Click on the link above to find Maltaannon’s tutorial.
    Kathlyn Lindeboom
    Creativecow.net
    Niklas Froese replied 18 years, 3 months ago 2 Members · 1 Reply
  • Niklas Froese
    June 7, 2008 at 8:10 am
    hey! i know it’s some time ago, this tutorial was up, but i just discovered it. it was very useful for me, because your technique nearly solves all of my problems. but there is one more challenge, which i personally can’t compete with.
    so you chained the different segments through expressions. they tell the segment, that they should have the position the previous segment had (eg) 2 seconds before. I’m fine with that.
    but this technique only works, if you have a constant speed. what, if i want to have a snake accelerating? (this is actually what i want) is there any fix to this solution?
    something like making the time-controller dependent of the speed?
    hope anybody can help 😉 thanks, niklas
