Activity › Forums › Adobe After Effects › COW Reviews: After Effects CineLook 2 or Magic Bulet 2.1–Which to Use?
Posted by Kathlyn Lindeboom on April 6, 2006 at 2:51 am
&page=https://www.creativecow.net/articles/johnson_tim/cinelook_vs_magicbullet/index.html”>CineLook 2 or Magic Bulet 2.1–Which to Use? Tim Johnson takes a thorough look at both CineLook 2 from DigiEffects and Magic Bullet 2.1 from Red Giant Software and determines that while at first glance they do the same thing — the film look, they are two very different products. Read the review to find out which product would best suit your needs.
Click on the link above to read Tim’s article
Kathlyn Lindeboom
Creativecow.netTim Johnson replied 20 years, 5 months ago 4 Members · 6 Replies -
Barend Onneweer
April 6, 2006 at 12:40 pmTim… if you’re reading this, what system were you using for the benchmark, and what kind of resolution were you working on?
And did you render Magic Bullet Look Suite with GPU enabled? Because if you have a decent graphics board, Look Suite soars! Just a quick comparison:
PAL comp, 7 seconds long:
Look Suite (Crime Scene preset)On my dual Opteron 244, it renders in 6min10sec
On the same machine with GPU enabled (nVidia 6800GT), it renders in 41 seconds!That’s without Magic Bullet de-interlacing and de-artifacting. The de-interlacer is still slow.
Bar3nd
Forum COWmunity leader for:
ADOBE AFTER EFFECTS
MAGIC BULLET SUITE
INDIE FILM & DOCUMENTARY -
Walter Biscardi
April 6, 2006 at 2:06 pmI tested CineLook 2 last year for the Cow and found it to be very very slow on the rendering side. Boris Continuum Complete offered far better rendering speeds and I can achieve pretty much the identical looks from that product.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Tim Johnson
April 10, 2006 at 6:48 pmBarend–
I was using just a single Xeon processor system on an SD project. I did not have GPU enabled. I will try to go back and see if my card can handle it. (It’s three years old–I’m not holding my breath.)
Man, that’s a HUGE difference in render times. Thanks for bringing this up.
Tim Johnson
KUTV 2 News
Salt Lake City, UT -
Tim Johnson
April 10, 2006 at 6:55 pmWalter–
I don’t have Continuum Complete to compare it to. I just loaded both (CineLook 2 and Magic Bullet Suite 2.1) on the same system and compared. For me, C2 didn’t seem much like a render hog. Bang for the buck, I thought it did a pretty decent job. I’m not necessarily using it for break-neck deadlines, though. I set up about 20 minutes worth of footage to render overnight, and it was done by the time I checked on it.
With regards to your solution in Continuum Complete–does it have a 3:2 introduction solution, or are you using AE’s? Were you already shooting 24p? Did the results work out well for you? I’d be interested to find out how you did it.
Tim Johnson
KUTV 2 News
Walter Biscardi
April 10, 2006 at 7:23 pm[Tim Johnson] “With regards to your solution in Continuum Complete–does it have a 3:2 introduction solution, or are you using AE’s? Were you already shooting 24p? Did the results work out well for you? I’d be interested to find out how you did it.”
I use AE’s 3:2 and I tested it with regular 29.97 BetaSP material. The results between CineLook 2 and Continuum were very close in terms of appearance, but for render times, Cinelook was just out of the ballpark in terms of what I could ever use in day to day work here. Continuum renders much much faster with their film effects.
Tim Johnson
April 10, 2006 at 7:32 pmDid you need the grain features in C2? I generally turn those way down or off, but I do like their pull-down, time slur, etc. I will look into Continuum. Thanks for the heads-up, man.
Tim Johnson
KUTV 2 News
Salt Lake City, UT
