Activity Forums Maxon Cinema 4D coverting instance object to editable doesnt convert the keyframes
  • coverting instance object to editable doesnt convert the keyframes
    Posted by Ronny Traufeller on February 12, 2014 at 8:09 pm
    i just build a bigger scene including
    instance objects ( a null with a cube inside )
    now it turns out
    that there are no keyframes existing after
    making all the instances to objects.
    a little bit disappointing now,
    is it the only truth?
    not much checkboxes available..
    thanks,
    Ronny
    traufeller.de
    Ronny Traufeller replied 12 years, 6 months ago 2 Members · 4 Replies
  • Brian Jones
    February 13, 2014 at 2:27 am
    I’d have to see the scene what I think you are taking about should work
  • Ronny Traufeller
    February 13, 2014 at 11:05 am
    well sure!
    here you have it..
    finally i done it by keyframing it afterwards again,
    it seems like also it will not spread objects
    into the disired layers from the original object…
    thanks,
    Ronny
    7124_roomtransitionturnboxesv031.c4d.zip
    traufeller.de
  • Brian Jones
    February 13, 2014 at 3:21 pm
    I see where the animation went – it’s really a null in a null which then has the objects in it and it’s the ‘inner null’ which has the rotation. When made editable you only get the animation of the outer object (the top null) which doesn’t have any animation. Xrefs would do what you wanted but not instances – though you could have done instances of the ‘cube’ null and put those in place (position/scale/rotate) and it would have worked.
  • Ronny Traufeller
    February 13, 2014 at 5:11 pm
    thanks!
    i think xrefs could will be fine!
    ronny
    traufeller.de
