Activity › Forums › Apple Motion › CoverFlux Plug-in Cannot Render
  • CoverFlux Plug-in Cannot Render
    Posted by Jason Diebler on December 16, 2009 at 6:46 pm
    This plug-in was working for me 1 week ago, not sure what I’m missing…
    Error Message Reads: “CoverFlux Plug-in Could Not Render Because Some Assets Could Not Be Loaded: If this plug-in loads assets such as images or RSS feeds from disk or the network, please make sure that the resource it is trying to access is available”
    The resource I’m trying to access is available. I also tried using the plug-in in FCP, same error. In fact, error occurs before I’ve designated a directory path, then gives me the spinning beach ball and locks me up. Other Industrial Revolution Plug-ins work fine. I’ve trashed Motion & FCPs preferences & repaired disk permissions. Thoughts?
    “The deepest blues are black” – Foo Fighters
    (this doesn’t help me when I’m chroma keying!)
    Mark Spencer replied 13 years, 8 months ago 4 Members · 4 Replies
  • Peter Wiggins
    December 16, 2009 at 11:21 pm
    Jason,
    So have you done anything different from last week? Installed any updates etc?
    Peter
  • Jason Diebler
    December 17, 2009 at 4:44 pm
    Peter, no, I don’t think I’ve done anything different, other than maybe a Security Update.
    I’m running Motion 4.0.1 and FCP 7.0.1 on a 2 x 3 GHz Quad-Core Intel Xeon, running OS 10.6.2.
    I tried the plug-in on a colleague’s machine (which it was also working on 1 week ago), and I got the same error. The error actually occurs the moment the CoverFlux effect is applied (before you even seek out a directory path). So the error message seems to be incongruous with whatever is actually causing the error.
    I agree with your logic though, something must have been recently introduced to the equation that is causing the error.
  • Alvarez Jaime
    January 16, 2013 at 8:39 pm
    Hello,
    I have the same problem.
    Any idea?
    Thank you
  • Mark Spencer
    January 16, 2013 at 9:34 pm
    I would contact tech support for idustrial revolution, who makes that product.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
