Activity Forums Adobe After Effects Expressions Counting up slider expression: smooth opacity/overlap transition
  • Counting up slider expression: smooth opacity/overlap transition
    Posted by Meg Alyce on June 7, 2015 at 12:46 am
    I’ve just created my expression code for a counting slider and the numbers I am using are from 90,000 – 100,000 so there’s quite a lot of jumping when the numbers count up.
    I’m wondering if there’s any effect that can be used to make the text opaque as it transitions or have the numbers overlap somehow so it doesn’t appear so jumpy?
    Peter Diefenthaler replied 11 years, 3 months ago 2 Members · 1 Reply
  • Peter Diefenthaler
    June 7, 2015 at 8:53 pm
    CC Wide Time would work for this. Play with the number of steps for desired smoothness. However, the numbers have to last more than just a few frames or the transition won’t look very good. Hope this helps.
    Peter Diefenthaler
    https://www.ideafirecreative.com/
