Activity Forums Adobe After Effects Expressions Counting Expresson not working.
  • Counting Expresson not working.
    Posted by John Cuevas on February 15, 2012 at 7:58 pm
    I add this expression to my Source text and I keep recieving an “invalid numeric result(divide by zero?) error.
    If I change the “myNum = time” no error, it displays time + percent. Also if I just link to the slider, no error, my number is displayed.
    It’s not that I can’t just put a percent sign behind the counter, I want to know why this isn’t working
    myNum = effect("Slider Control")("Slider");
    myNum + "%"
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
    John Cuevas replied 14 years, 6 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 15, 2012 at 8:33 pm
    Sometimes the expression engine doesn’t automatically convert expression control objects to values and you have to explicitly tell it to do so, like this:
    myNum = effect(“Slider Control”)(“Slider”).value;
    myNum + “%”
    This is another way to fix it:
    myNum = effect(“Slider Control”)(“Slider”);
    “” + myNum + “%”
    Apparently forcing the string conversion (with the “”) also causes the value to be retrieved.
    Dan
  • John Cuevas
    February 15, 2012 at 8:36 pm
    Thank you Dan, that was driving me nuts. Good thing to remember for the future.
    Thinkck.com
