Activity › Forums › Adobe After Effects Expressions › Counter-Expression does not render in MediaEncoder
  • Counter-Expression does not render in MediaEncoder
    Posted by Isa Dimpfl on January 21, 2019 at 1:24 pm
    hi folks,
    i have a problem rendering a simple counter expression in AE on a text layer:
    this counter does not render in media encoder (just the still text is showing as if the expression simply doesnt work), but when i scrub through the comp, it is perfectly counting from 0 to 350.
    when rendered whit the AE internal renderer everything works.
    effect("Slider Control")("Slider").value.toFixed(0) + "mm";
    Isa Dimpfl replied 7 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
