Activity Forums Adobe After Effects Expressions Couldn’t find layer…that is there
  • Couldn’t find layer…that is there
    Posted by Matthew Tully on June 12, 2008 at 3:54 pm
    Hey friends,
    I’m working on a project that keeps giving me an error I don’t understand. I understand how to read the error I just don’t get why it’s happening.
    Here is the expression used on a layers scale property:
    temp = comp(“montage”).layer(“Controller”).effect(“Scale FG”)(“Slider”);
    [temp,temp]
    Here is the error:
    After Effects warning: Bad argument: couldn’t find layer named “Controller”
    Expression Disabled.
    Error occurred at line 1.
    Comp: ‘photo mix”
    Layer: 2 (‘people’)
    Property: ‘Scale’
    Simple enough right? No. The issue I’m having is the layer “Controller” does exist. It’s one step up from the nested comp. I have even pick-whipped to it to make sure syntax is ok, and it is still telling me it’s missing.
    The top layer of the project has a bunch pre-comps all called “montage.” Every pre-comp has the exact same syntax, could this be throwing things off? Having the same name?
    Please help.
    Rolf Fuehringer replied 18 years, 1 month ago 3 Members · 6 Replies
  • Matthew Tully
    June 12, 2008 at 5:37 pm
    Along the same lines can I turn something like
    comp(“montage”).layer(“pic control”)
    into something like
    thisComp.parentComp.layer(“pic control”)
  • Dan Ebberts
    June 12, 2008 at 5:59 pm
    Yup. It will check the first “montage” comp it encounters in the project bin for a layer named “Controller”. If it doesn’t find the layer in that comp, you’ll get the error.
    edit: Actually, it might be the last one it encounters. Same issue though.
    Dan
  • Dan Ebberts
    June 12, 2008 at 6:01 pm
    Nope. No way to get to a comp’s parent comp except by name.
    Dan
  • Matthew Tully
    June 12, 2008 at 6:23 pm
    Thanks Dan.
    Is there any way to look into folders in the bin from the same expression?
    As usual, you are a rockstar!
    – Matt
  • Dan Ebberts
    June 12, 2008 at 7:44 pm
    No. You can do it with a script (in a round-about way), but not an expression.
    Dan
  • Rolf Fuehringer
    July 14, 2008 at 10:30 am
    Hi Dan,
    You really saved my day!!! That was exactly the right solution for my problem here!
    Just wanted to say thanks!
    So – Thanks 😉
    regs Rolf
