Activity Forums Adobe After Effects Could someone please tell me how to fix AE please! If you know anything about ASLfoundation.dll I will supply you with anything for a great while.
  • Could someone please tell me how to fix AE please! If you know anything about ASLfoundation.dll I will supply you with anything for a great while.
    Posted by Marcel Rod on October 3, 2011 at 1:41 pm
    Please help (i cant write the other word) me. After Effects starts and then says some long error 4 times. AE starts, but it takes 5 minutes to start it.
    If you can rhelp me, I will be very grateful.
    – M
    Marcel Rod replied 14 years, 11 months ago 3 Members · 14 Replies
  • 14 Replies
  • Ben G unguren
    October 3, 2011 at 3:07 pm
    Sounds to me like you should reinstall the program.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Sean Mullen
    October 3, 2011 at 6:57 pm
    What version of AE are you using? I suggest trashing the preferences to see if you can avoid a re-install.
    To Create new AE Prefs in MAC/OS
    1. Quit After Effects.
    2. Drag the Adobe After Effects 9.0 Preferences file from the Users/Library/Preferences/Adobe/After Effects/9.0 folder to the Trash.
    3. Restart After Effects.
    Create new AE Prefs in Windows Vista
    2. Rename the Adobe After Effects 9.0 Prefs.txt (ex Adobe After Effects 9.0 Prefs.old) in the C:\Users\AppData\Roaming\Adobe\After Effects\9.0 folder.
    3. Start After Effects. After Effects creates a new preferences file.
    Sean Mullen
    Rampant Design Tools
  • Marcel Rod
    October 6, 2011 at 1:22 pm
    Thank you so much Sean. But I use AE CS4. Could you help me with that?
  • Sean Mullen
    October 6, 2011 at 3:09 pm
    Try restarting After Effects while holding down the Command + Option + Shift keys (Mac) or Control + Alt + Shift (PC). This should give you an option to delete the preferences.
    Sean Mullen
  • Marcel Rod
    October 8, 2011 at 9:03 pm
    Thanks again Sean, you are awesome! The people in life that know more, and teach it to others, are the hero’s in life. But before I delete the preferences file, what does it do exactly. It would be great if you would answer me somewhat detailed 🙂
    -M
  • Sean Mullen
    October 9, 2011 at 12:29 am
    Thank you for the kind words! Basically it resets everything to the default installation settings.
    Here is a link to the official and very detailed list of AE preferences from Adobe.
    Sean Mullen
  • Marcel Rod
    October 9, 2011 at 5:11 pm
    I have some free plugins as well. It took some time to gather them. This will not delete them will it?
    Thanks again,
    -M
  • Sean Mullen
    October 10, 2011 at 1:07 am
    This will not delete your plugins. This only resets the AE preferences to their default states.
    Sean Mullen
  • Marcel Rod
    October 10, 2011 at 1:53 pm
    Sorry, it didn’t help. But the error says something about a UMCDecoder or something like that. Could you mail me your ASLfoundation.dll plus the UMCdecoder? I would appreciate that a lot. Thanks for your help Sean! If you decide to send something remember that I have CS4, and that my e-mail is TheMysteriousMrM@hotmail.com.
  • Sean Mullen
    October 10, 2011 at 2:55 pm
    Unfortunately, I’m not running CS4. I have CS 5.5, so I do not have the files that you need. Perhaps you should backup your plugins and re-install?
    Sean Mullen
