Activity Forums Apple Final Cut Pro Could a eSATA Hub cause any problems when editing on FCPX?
  • Could a eSATA Hub cause any problems when editing on FCPX?
    Posted by Peter Dunphy on March 14, 2014 at 12:11 pm
    Hi Guys
    For editing with FCPX 10.1 on a iMac (27-inch, Late 2012), which has thunderbolt ports, would it be possible to connect a 3TB G-Speed Q external hard drive via its eSata connection (it doesn’t have thunderbolt ports), via something like a LaCie eSATA Hub?
    If so, could the eSATA hub cause any problems by running the video data through it rather than directly to the external drive?
    Would it be better for FCPX editing to purchase an external hard drive with a thunderbolt connection?
    Bret Williams replied 12 years, 5 months ago 2 Members · 1 Reply
  • Bret Williams
    March 14, 2014 at 3:14 pm
    I don’t know what speeds you need, but a $15 usb3 to esata adapter cable will give you standard esata single drive speeds. Which should be fine for HD editing. Some claim to support port multiplication which should support an esata raid, but I’ve seen mixed reviews.
