Activity › Forums › Apple OS X › Corrupted login: can’t access files Please Help!
  • Corrupted login: can’t access files Please Help!
    Posted by Riclbs on June 10, 2006 at 4:50 am
    My friend has two logins on his iMac and one of them has some kind of corruption that prevents the finder from opening. I tried to access the desktop files he needs from that login from the working one but the all the folders under his login are marked with a red minus sign and I cannot open them. I checked permissions and did a get info that said that I don’t have permissions access. What can I do to retrieve his files? Thanks in advance.
    iMac 256k ram, 700 MHz processor
    Kyle Rarey replied 20 years, 3 months ago 3 Members · 2 Replies
  • Simon Carlson-thies
    June 10, 2006 at 7:42 pm
    First Backup your files as soon as you get them back…!
    Try doing a safe boot and see if your computer will start… because the reason for your login troubles may be a corrupt login item
    Also boot off of the system disc and verify disc… and reset your password from the same menu
    if this doesn’t work then…
    try removing your preference folder either the easy way or via command line in single user mode see if that fixes the problem… if not post back
    Simon Carlson-Thies,
    Digital Light Graphics And Animation
  • Kyle Rarey
    June 19, 2006 at 12:13 am
    I recently had a similar problem with my iBook on OS 10.4
    Many things I tried would work for a short time, but the ultimate solution ended up being to boot the iBook into FireWire Disk Mode (Holding gown ‘T’ at the startup chime, if I remember correctly), attaching it to another mac with a firewire cable, disabling permissions on the mounted HD (Get Info > Ignore Permissions on this Volume) and copying my files out before formatting and reinstalling.
    Hopefully you won’t have to resort to such a drastic move, but it ended up being the only thing that fixed mine.
