Activity Forums Adobe Premiere Pro Corrupted File
  • Corrupted File
    Posted by Dan Cramer on October 18, 2010 at 4:12 pm
    On Friday, I was given approval a long stalled project in Premiere cs4. I realized that I had mistakenly deleted a few files. So I imported an m2v file from the approval DVD I made for my boss. I replaced the missing footage with clips from the m2v file. Then Premiere crashed. Which is not uncommon as the computer I edit on is less then ideal for editing.
    When I restarted the program and tried to open the project it froze at 75 percent. I opened the most recent auto save and repeated importing the m2v. It happened again. So i converted the m2v to an Avi. Before I left Friday afternoon everything seemed to be fine.
    I tried opening the clean project this morning and it froze again. My back up of the project without what I thought was the corrupt file won’t load either.
    I’ve deleted the media cache, and the temp files. It hasn’t help. Premiere won’t import the project into a new project. And other projects open fine.
    What can I do to get the project to open correctly?
    Mercer Macwilliam hughes replied 8 years, 3 months ago 11 Members · 20 Replies
  • 20 Replies
  • Dan Cramer
    October 18, 2010 at 5:06 pm
    Just send you the project file?
  • Vince Becquiot
    October 18, 2010 at 5:08 pm
    Yes
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Vince Becquiot
    October 18, 2010 at 5:55 pm
    Sent out what should be a fixed version your way. Let me know how that works out…
    Vince Becquiot
    Kaptis Studios
  • Alex Udell
    October 18, 2010 at 7:03 pm
    Hey V…
    do you have some magic tools that open the binary for editing?
    Alex
  • Vince Becquiot
    October 18, 2010 at 7:08 pm
    There are a few options. First, rename to XML and open in XML Wrench, use the repair option in the menu. That should fix any obvious problems. I usually also quickly go through the headers to catch obvious problems, it helps to know XML 🙂
    Another option that sometimes works but usually comes at the cost of some re editing is to import the file into After Effects then re-export as a Premiere project.
    With all of these options, you can can get a workable file in most cases.
    Vince Becquiot
    Kaptis Studios
  • Alex Udell
    October 19, 2010 at 8:19 pm
    Wow…interesting…
    a .Prproj is an XML file?
    What would stop you from opening it in a text editor?
    Anything?
    Alex
  • Vince Becquiot
    October 19, 2010 at 8:22 pm
    You could open it in a text editor, it just doesn’t give you that nice color coding and repair options.
  • Harvie Dela peña
    January 27, 2011 at 7:49 pm
    sir i am using premiere pro cs5 and the project file that ive been working as of now is damaged…ive tried everything that the forum has said…are there any ways that i can fix this problem…thank you,,,
  • Vince Becquiot
    January 27, 2011 at 11:25 pm
    Send it my way (vince (at) kaptis .com, I’ll check to see if I can do something with it.
    Vince Becquiot
    Kaptis Studios
  • Paul Toth
    July 22, 2011 at 10:41 pm
    Interesting… good to know this!
    so I compared my damaged file (PPro CS5.5 project) in XML Wrench with a auto save file from the same project… the auto save file has a lot of data in it, but the project file is blank… nada…
    Tried the AE trick.. no go…
    Power bump is what killed my file… I guess Premiere doesn’t actually save any data in the file until it has to…?
