Activity Forums Apple Final Cut Pro Legacy Corrupt render files
  • Corrupt render files
    Posted by Michael King on January 8, 2009 at 7:24 am
    Hello All,
    I’ve been working away with everything going great until… I render something. Before I posted this I searched past posts for anything and found this earlier this year:
    Corrupt render files? by Christopher Knell on 2008-03-29 00:52:59
    https://forums.creativecow.net/readpost/8/981147
    He has the same source footage, sequence settings, and pretty close to the same system, and even his jpeg looks similar although better than me (my problem looks like more little green squares and less video) The other thing is I will render clip by clip, and it plays fine, then come back later and its green squares time. I’ve done all the fix it recommendations as suggested in the post above but I haven’t come to Christopher’s happy ending. Time is beginning to run out so I would greatly appreciate any ideas at this point.
    Mike
    Michael King replied 17 years, 8 months ago 4 Members · 11 Replies
  • 11 Replies
  • David Roth weiss
    January 8, 2009 at 2:10 pm
    Pretty tough to help without any info, such as the codec you’re using. Why not help us to help you?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Michael King
    January 8, 2009 at 5:38 pm
    I apologize, I for some reason thought that the past post had more info than it did. Anyway, I shot footage on a HVX-200 at 720P/24PN. The Sequence settings are Frame size: HD (960×720), Pixel Aspect Ratio: HD (960×720), Editing Timebase: 23.98, Compressor: DVCPRO HD 720p60.
    I’m running: Final Cut Pro 6.0.5 on a PowerMac 2×3 Ghz Quad-Core Intel with 4 gb ram, OS 10.5.6, Kona LHe card,
    Atto 4 gig fibre channel card to a Ciprico Mediavault Raid w/1.2tb. If that’s any help.
    Now here is another thing, in responding and checking my system in About this Mac, I’ve noticed half of my ram is gone. I should have 8gb. Huh!
    If there is anything else I can do to help you help me, please let me know.
    I’m extremely grateful and again apologize for the lame post.
    Mike
  • Michael King
    January 8, 2009 at 6:18 pm
    In my own response to my last post, I’ve pulled the processors, reseated the ram and now have all my ram back, however the render “confetti” image I get is still there.
  • David Roth weiss
    January 8, 2009 at 6:49 pm
    Michael,
    If I were you, I would uninstall the Kona drivers using their uninstall utility (it gets installed in your Applications folder along with the other Kona apps). Then reinstall either he latest drivers or the same ones you had before.
    I have had great success with this procedure…
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Michael King
    January 8, 2009 at 7:34 pm
    David,
    Thanks for the reply. I did the uninstall and then installed the latest driver from AJA. I couldn’t use my original disk because it said it was to old as I had updated (I believe the firmware) some time ago.
    Unfortunately, the confetti is still there. To clarify the problem, I will render an effect ( this doesn’t matter if it’s a Magic Bullet Looks effect, a Motion project, or a simple FCP color effect that will play without rendering) the clip will play for a bit then get these hits for a second or so. I’ve been deleting the render files then re-rendering until I get a good one, only to come back later and find some “good ones” are no longer any good at all. Everything looks great, plays great, until I render.
    Any other thoughts would be greatly appreciated.
    Thanks again,
    Michael
  • David Roth weiss
    January 8, 2009 at 7:51 pm
    10-bit rendering was an issue with one of the FCP or QT updates, but it doesn’t sound like that is the case for you. I’m sorry, but I’m stumped…
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Michael King
    January 8, 2009 at 9:36 pm
    Thanks for the help David, If you have any work-around ideas or if anybody else has anything… the fear is starting to creep in now. I’m not ruling out pilot error, in fact I’m hoping it’s something really stupid.
    I’ve not let myself down in that regard before.
    Thanks again,
    Michael
  • John Pale
    January 9, 2009 at 5:48 am
    I had a problem once with a Huge Systems (now Ciprico) external RAID that caused intermittent artifacts not unlike what you are describing. They sent me updated firmware and the problem disappeared.
  • Michael King
    January 9, 2009 at 5:54 am
    Thanks John,
    I’ve found a previous post on the Cow that suggests AJA doesn’t like OS 10.5.6 so I am re-installing a previous version right now. The raid will be my next target!
    Thanks so much for the post!!!
    Michael
  • Bob Pierce
    January 12, 2009 at 12:06 am
    Michael,
    Did you ever solve your problem? I’ve come across the same thing – blocky green pixelation in renders. I’m working with Kona 525 29.97 Prores 422 (with media captured with same codec). I find that if I change the sequence settings to DVCPRO 50 and rerender, things look OK. I’m rending clips with CC and Magic Bullet Looks applied.
    Bob
    Mac Pro 2.66 – 8GB memory – Mac OS 10.5.2 – Quicktime 7.4.5 –
    Mac Book Pro 2.33 Duo –
    FC Studio 2 (Final Cut 6.0.3) – Kona Lhe
    Adobe Production Suite CS3 –
    Sony Multiformat 14″ – Panasonic 42″ Plasma –
    Ikegami HLDV7 – PVW EX-1
