Corrupt P2 Files, P2 LOG Pro, and 8K corrupt quicktimes
Greetings…!..
I am working on a film in which several of the P2 card backups are corrupt… i.e, after the shoot when importing into FCP, the cards failed to read.
I purchased P2 log pro and used the Repair wizard to repair each clip. The repair processed appeared to work becuase when I reopened these new files, the video and audio played within P2 Log via its clip viewer. Unfortunately, when I try to import this new card into FCP, the program crashes… this crash occurs on both the newest update (5.1.4) and an older version (5.1.0).
When I try to export the file from within P2 Log as an FCP XML, the render time corresponds to the length of the quicktime, however the resulting file is always an 8K corrupt quicktime file. This is very odd considering the file played fine within P2 Log.
Any advice on making this useable files? Thanks for the help!
-Corey
Corey Bayes
corey.bayes@gmail.com
