Activity Forums DSLR Video corrupt mov file from 7d
  • corrupt mov file from 7d
    Posted by Tali Clarke on August 23, 2012 at 8:45 pm
    Hello!
    Just wondering if anyone had any nuggets of wisdom about corrupt mov files created by the 7d..?
    Been shooting on the Canon 7D with Sandisk 32gb 60mb/s card – a realtively new one, at the time no error message was given, (or that annoying ‘busy’ message that sometimes pops up before it crashes!) – but now, when I moved the files over to my hard drive one of the files is not read as a movie file (even though it is over 3gb on the disk), and when putting the card back into the camera it seems to be gone all together, with no thumbnail or option to play back.
    I’ve read a few forums stating problems with the 7d firmware, and possibly large format cf cards, but was just wondering if anyone had any free/cheap suggestions as regards to recovering the data, as I really need the content of that mov file!
    Any help massively appreciated.
    Cheers, Tali
    Cri Cri replied 12 years ago 14 Members · 15 Replies
  • 15 Replies
  • Casey Petersen
    August 23, 2012 at 8:58 pm
    Have you looked into Treasured? https://aeroquartet.com/
  • Tali Clarke
    August 23, 2012 at 8:59 pm
    yea i downloaded that but every time i try to open it it unexpectedly quits straights away…strange
  • John Young
    August 23, 2012 at 9:05 pm
    Depending on the value you place on that file… Treasured has saved me on two occasions, but it isn’t too cheap, $50 per file, I think.
    By the way, I think I have determined that the cause is starting & stopping recording too fast. At least that is my suspicion. It is the only time I have ever had that error happen.
    John
  • Chris Wright
    August 23, 2012 at 9:18 pm
    if there is data there, data recovery wizard professional can get it. but if the file itself is corrupted, use virtualdub to rebuild the broken index file. you might have a missing frame, cut it or blend 2 adjacent frames with timewarp.
  • Cri Cri
    August 25, 2012 at 12:44 pm
    As data recovery tools you can try:
    – GetDataBack for FAT (https://www.runtime.org/data-recovery-software.htm)
    – Partition Recovery or UnEraser from DiskInternals.com
    If you do recover a MOV file, you can then use VideoRepair utility (https://grauonline.de/cmsimple2_6/en/?Solutions:HD_Video_Repair_Utility) which as a demo only recover half of the movie, but you can always do “copy FILE000.mov+FILE000.mov DOUBLE.MOV” 🙂
    Ah, the video repair utility requires a previous MOV file recorded with ur camera to use it a sa template or something.
  • Sid Manny
    September 20, 2012 at 7:34 pm
    You can use MOV repair tool to repair the corrupted MOV files on Mac PC. Previously I was able to fix MOV file on MacBook Air when the MOV file is corrupted using this tool. It worked with the good results. You can download the trial version available on the official website and evaluate the recovery results before purchasing the software. Good luck
  • Christopher Isaac
    December 28, 2012 at 10:08 am
    Corrupted mov file can be recovered with the help of MOV recovery utility on your computer. the utility’s simple wizards lets you perform the recovery easily within few clicks. Its steps can be found at https://video.mov-recovery.com
  • Tyu Akmal
    January 2, 2013 at 7:14 am
    if you are experiencing the problem with corrupted mov files. to get rid of you can use MOV file Recovery tool, i used this tool to repair our mov file, i hope this tool will also help you to know more about it you can visit https://freeware.movrecovery.net
  • Tyson Granger
    January 9, 2013 at 5:24 am
    Hi All,
    Have you tried repair software called Yodot MOV Repair? This repair utility fixes MOV file corruption which are usually caused due to CRC error, improper file operation, virus attack or any other reason. This tool is among the finest software to repair CRC error in MOV file. So don’t hesitate to download the trial version of the software to check its performance
  • Sharon Charles
    January 12, 2013 at 6:56 am
    Most of the digital gadget uses mov files. Most and nearly every digital gadget uses memory card to store photos or video . But one of the common problem related with memory card is that it often prone to corruption resulting in loss of data stored in it. In order to recover and restore data it is safe and secure to use photo recovery tool.
    https://camera.picturerecoverysoftware.net/
