Activity Forums DSLR Video corrupt mov file from 7d
  • Sally Bin
    June 17, 2013 at 10:43 am
    For broken or corrupt .MOV file you must have to repair those files with powerful Photo recovery software.Since this file format is commonly used in popular devices which helps you to store number of MOV files through powerful storage space scanning of used devices. Last month I was in a same critical condition when I lost MOV files from my memory card. Then I use MOV file repair to fix the problem. Thanks for a lot for this helpful instructions.
    For more information visit: https://www.macphotosrecovery.khozz.com
  • Andrew Symonds
    June 8, 2014 at 1:20 am
    Are you wondering after losing access to MOV file from Canon 7D? Well, stop wondering and use Remo Repair tool to fix MOV, MP4 and other videos.
  • Tina Hofman
    June 24, 2014 at 11:29 pm
    Have same problem here, luckily found this solution:
    https://goo.gl/XPwK7
    It works like a charm. Try it if you need to recover data from canon camera.
  • Abidemi Oderinlo
    August 29, 2014 at 6:37 pm
    @Christian Chiru can you please explain the FILE000.MOV+FILE000.MOV you suggested, i’m a bit lost..
  • Cri Cri
    August 30, 2014 at 2:51 pm
    Wow, this is a very old post 🙂
    The limitation of that software was that it processes only 50% of the file.
    So, to overcome this, one can simply create a file by appending the file to itself, creating a movie with twice the same data. So the program will fix the first half which is in fact our main movie.
    The copy command can create a file by concatenating other files:
    copy input_file+input_file2+…+input_fileN output_file
    So, by using:
    copy FILE000.MOV+FILE000.MOV DOUBLEFILE.MOV
    and then running the program to fix it, the output would be your main movie repaired (if not too corrupted).
Page 2 of 2
