Activity Forums Adobe Photoshop Corrupt Ilutrator CS2 File
  • Corrupt Ilutrator CS2 File
    Posted by Julio Crespo on March 4, 2007 at 9:20 pm
    I have .AI File that when I try to open an error message appear.
    Can’t open the illustration. The Illustration does not have the correct number of operand for an operator
    Offending operator “m”.
    Any idea?.
    I can open the file placing in a fresh document, but the image has flatten, I need to have access to the vector, text, ect.
    Vincent Rosati replied 19 years, 6 months ago 3 Members · 3 Replies
  • Mike Gondek
    March 5, 2007 at 3:43 pm
    Check the name of your file to have alphanumerics. I remember somehting abotu a file with a comma in the name and an operand error came up. You can use dashes, underscores and quite a few other charchters, but just change the filename to x.ai and see if it opens.
    We sued a similar technique to open CS2 files in CS1 of placing the ile in a new docuemnt Once it came up bitmapped, so we used expand and it fixed the logo.
    There is a small chance expanding will work for your corrupted file, otherwise I think your file is in bad shape unless running a hard disk utility may fix some blocks on your drive that may be crosslinked.
  • Julio Crespo
    March 5, 2007 at 9:02 pm
    the expand option is turned off.
  • Vincent Rosati
    March 6, 2007 at 8:03 pm
    Also try…
    File/Place the corrupted file into a new AI file. or..
    Open the corrupted file with Acrobat and Save As: PDF or EPS or whichever.
