Correct Sequence Settings for t2i/HDSLR footage in CS4
Hey,
after the start up, you have to chose the sequence settings for your project.
The preset most fitting for the t2i footage in CS4 seems to be the “HDV 1080p24” setting.
However, several things are not quite right with this preset:
– it says HD anamorphic (1,333), while my footage is (1,0) and as far as I know not anamorphic
– the size of the “comp” is 1440 x 1080, while my footage is 1920 x 1080Any suggestions how to handle that? How do you set up your PPro correctly for HDSLR footage?
I think I remember that CS5 upwards has presets set out for HDSLRs… Again: Would an update be the best option?
Thanks for your help in advance
See you
Steffen
