Activity › Forums › Panasonic Cameras › Correct firewire output for HD mode?
  • Correct firewire output for HD mode?
    Posted by Nelson May on June 30, 2007 at 3:52 am
    I am trying to get my G4 to see 1080 via firewire into HD monitor pro. The program can see SD without a problem. When I power down and flip the switch to P2 mode, I can’t get a signal over the firewire into my G4. I am set at 1080 which HD monitor pro uses.
    Any thoughts. I am new to HD, but not SD and am still wading though this camera on the HD end. Let me know if I have a menu preset wrong.
    Thanks.
    David S. replied 19 years, 3 months ago 3 Members · 2 Replies
  • Michael Sacci
    July 1, 2007 at 12:22 am
    I need a program like Scopebox.com (there is another one that is cheaper but I cannot remember the name). This also gives you scopes
    You cannot capture anything but DV25 to FCP unless you have product.
  • David S.
    July 2, 2007 at 2:36 pm
    If you do not have the DVCProHD codecs installed on that G4, I don’t believe HD Monitor is going to work with that codec.
