Activity › Forums › Apple Final Cut Pro Legacy › Correct exporting of a rendered video from Final Cut Express 4
  • Correct exporting of a rendered video from Final Cut Express 4
    Posted by Brandon Eastman on February 17, 2012 at 2:27 pm
    I just finished editing a video for class and would like to export . /The /files /I /worked /with /came /from /a /Flip /Cam /and /imported /into /FCE4 /as /follows: Frame /size /1280×720 /60fps /compressor /h.264 /44.1 /khz /audio /32 /bit /floating
    How /do /I /export /properly /as /to /get /the best /picture /quality. /Do I /export /using /QT /conversion /and /match /the /settings /listed /above ? /Exporting /properly /always /seems /to /confuse /me /bc /the /quality /is /bad /when /ever /I /do /it. That /degradation /in /picture /just /messes /with /the /flow /of /the /video /and /becomes /distracting /to /me.
    Thanks /for /the /help, /and /sorry /about /the /slashes, /my /keyboard /is /messed /up /and /deleting /each /slash /is /quite /time /consuming!
    Rafael Amador replied 14 years, 7 months ago 2 Members · 1 Reply
  • Rafael Amador
    February 17, 2012 at 5:27 pm
    Hi Brandon,
    The problem with FCE is that internally renders everything in the AIC codec which is not very good.
    Not sure if you will get anything better exporting with QT Conversion.
    Try it, and yes, matching the setting of the footage except the codec. Try with something better than the AIC (if available) and avoid H264 unless you are making a video for internet..
    rafael
    http://www.nagavideo.com
