Activity Forums Adobe Premiere Pro Correct Export to DVD Settings?
  • Correct Export to DVD Settings?
    Posted by Christopher Joseph on June 20, 2007 at 7:40 pm
    I’m experiencing some ghosting/soft-strobing issues when exporting to DVD. I’m assuming my export settings are wrong.
    The project is DV 720×480, 16×9, 24p(A).
    Editing Mode: DV 24p
    Timebase: 23.976 frames/second
    Fields: No Fields (Progressive Scan)
    Display Format: 24fps Timecode
    Capture: DV Capture
    Playback Settings
    24p Conversion Method: Interlaced Frame 2:3:3:2
    Interpret Footage
    Use Frame Rate from File: 23.976
    x Remove 24p DV pulldown
    What should my export settings be (assuming I want the highest quality video)? The project is a 30 second spec commercial so space is not an issue.
    Any and all detailed help and explanations are greatly appreciated.
    Blast1 replied 19 years, 3 months ago 2 Members · 3 Replies
  • Blast1
    June 21, 2007 at 5:38 am
    Is this for playback on a NTSC DVD player or playback on a computer?
  • Christopher Joseph
    June 21, 2007 at 4:33 pm
    NTSC DVD player.
  • Blast1
    June 21, 2007 at 7:14 pm
    NTSC = 29.97 interlaced frames/sec
    For maximum compatibility a NTSC DVD should be 60i, to use 30p the DVD player should have progressive capability, if 30p is played to a normal crt tv it ends up interlaced anyway, to do 24p something has to be capable of doing a pulldown to view properly not saying that artifacts aren’t going to show up.
