Activity Forums Apple Final Cut Pro Legacy correct “Easy Set Up” choice for digitizing miniDV footage shot in 1999
  • correct “Easy Set Up” choice for digitizing miniDV footage shot in 1999
    Posted by Brian Lindstrom on June 11, 2011 at 2:18 am
    I am trying to digitize miniDV footage shot in 1999. I digitized it using the Easy Set Up Format: DV/Panasonic DVCPRO Rate:24:00fps Use: Cinema Tools–24fps from DV NTSC. The first few shots appear to be in sync, but the sync gets lost as the tape goes on. I assumed the footage was shot at 24 fps. Is there a better format, use and/or rate selection I should use?
    Brian
    Chris Tompkins replied 15 years, 3 months ago 2 Members · 1 Reply
  • Chris Tompkins
    June 11, 2011 at 5:19 pm
    DID you try the DV NTSC 48k easy setup? Perhaps your footage is 29.97
    Chris Tompkins
    Video Atlanta LLC
