Activity Forums Adobe After Effects Corner Pin Scaling help!!!
  • Corner Pin Scaling help!!!
    Posted by Ingo G on August 27, 2007 at 2:40 pm
    Hi all …
    I,m changing license plates on a car commercial here in iceland. I have got all the tracking good But im having trouble with scaled and stretch
    Sam Moulton replied 19 years, 1 month ago 2 Members · 3 Replies
  • Ingo G
    August 27, 2007 at 3:03 pm
    But let
  • Ingo G
    August 27, 2007 at 3:22 pm
    Thank you Thank you Thank you … This is about the only thing i didn
  • Sam Moulton
    August 27, 2007 at 11:43 pm
    I think this is about the only time you should use the fit command. Corner pin works best whe the footage is the same size as the comp. drop your plate image in a new same size as your project comp. use ctrl+aalt+f or cmnd+option+f to fit the plate to the comp. Drag this comp into the main comp and use it as the source for the corner pin. Everything should work just fine.
