Activity Forums VEGAS Pro Corner Pin, render quality questions
  • Corner Pin, render quality questions
    Posted by Ross Shain on June 19, 2012 at 1:15 pm
    Hi folks,
    Quick question from someone not running Sony Vegas.
    Assuming Vegas has a “corner pin” effect, does anyone know what render filtering it uses? (bi-linear, bi-cubic, Lanczos)
    -Ross
    Ross Shain
    Imagineer Systems
    http://www.imagineersystems.com
    John Rofrano replied 14 years, 3 months ago 2 Members · 1 Reply
  • John Rofrano
    June 19, 2012 at 3:10 pm
    Hi Ross,
    Vegas does not have a corner-pin effect. Since you’re from Imagineer Systems, I assume you know that corner-pin data from Mocha can be loaded into Boris FX BCC Corner Pin for Vegas Pro and used in Vegas. If you wanted to write something that loaded corner-pin data into Vegas natively you could use Track Motion keyframing. To my knowledge Vegas uses bi-linear when rendering in “Good” mode and “bi-cubic” when rendering in “Best” mode.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
