Activity Forums Adobe Premiere Pro Copy/Paste a title without altering it
  • Copy/Paste a title without altering it
    Posted by Jeff Gerst on July 19, 2011 at 7:56 pm
    I saw an old thread about this, but wanted to know if Premiere has updated this feature – Does AP CS5.5 allow you to copy and paste a title in a sequence and change it without changing the original.
    Is there a way to simply copy the title, paste in somewhere else in the sequence and have it be independent of the first title? My solution to date was to first duplicate the title in its Bin, then drag to the timeline.
    Thx.
    Nicholas Sousa replied 9 years ago 10 Members · 16 Replies
  • 16 Replies
  • Jeff Pulera
    July 19, 2011 at 8:22 pm
    Open the title, and at the upper left of the Titler window is a button that will duplicate the current title, with a new name, then you can make your changes.
    Jeff Pulera
    Safe Harbor Computers
  • Jeff Gerst
    July 19, 2011 at 8:41 pm
    Thx for the help! Still not as great as copy paste but helps!
  • Jeff Pulera
    July 19, 2011 at 8:49 pm
    Let me elaborate on my title workflow. I’m currently working on several dance recitals with a LOT of titles (one for each act), and I want to have a “template” for uniformity. I make the first title and place it, then copy/paste that “Title 1” into next slot, then open it in Titler by double-clicking on it in the sequence.
    I next hit the button to make a copy, and rename “Title 2” or whatever, then alter the title contents and exit. When I go back to Premiere, the “Title 1” is still highlighted, and I right-click and choose “Replace with clip from bin”, which is the latest “Title 2” I just created. Done! Automatically replaces with updated title and maintains the current length and any effects.
    Hope this helps
    Jeff Pulera
    Safe Harbor
  • Jeff Gerst
    July 19, 2011 at 9:23 pm
    Cool – just tried that & it is better – will work with that workflow & see if I can streamline – looks good so far… Thx!
  • Alex Udell
    July 20, 2011 at 12:54 am
    You are correct, versions need to be created in the project panel or title tool. Duplicates made in the sequence link to the same master clip.
    Alex
  • Carole Jones
    November 8, 2012 at 8:20 pm
    hi
    i want to copy a title 1 which I animated, paste it into a new slot (rename it) and then
    alter only text on the first title, without loosing the animation, how do I do that, kind of opposite of nesting…
  • Jeff Pulera
    November 8, 2012 at 8:48 pm
    Hi Caroline,
    Try this – copy and paste the title, then double click the copy to open in Titler, then click the button for “Create new titled based on current”. Modify the text and exit Titler (new title gets added to bin). Right-click on copied title on timeline, and select “Replace with Clip from Bin”. This should update clip to NEW title text, while keeping current effects attributes.
    Jeff Pulera
  • Dasantha Charith
    November 22, 2016 at 6:48 pm
    My idea is get rid of Premiere title and use photoshop page to write what you want and export a png images to Premiere
  • Gerrit Van dyke
    November 24, 2016 at 2:52 pm
    If you’re on a mac, click and drag it while holding option. That will make a duplicate that you can edit without changing the first one. I will sometimes do a copy and paste, then option drag it up a layer (and delete the old one).
    It’s one thing about Premiere that’s always a bit of a pain. Personally, I don’t need 75 files with uniquely named files. I never look at those filenames anyways… But the option drag thing works beautifully….
  • Gordon Lamont
    November 25, 2016 at 10:01 am
    For PC
    In the timeline hold alt and drag the title to where you want the next one to be. You have now created an editable copy that will not affect the original.
