Activity Forums VEGAS Pro Copying/Importing Bins from one project file to another
  • Copying/Importing Bins from one project file to another
    Posted by Andre Anthonio on August 27, 2012 at 3:03 pm
    Hello there all: I can’t seem to find anything in the forums which addresses how to quickly copy a bin (and all of its contents) from one project file to another? I’m working with Pro 11 and it would be very helpful to copy and paste a bin from one project to another to save time. Right now I have to re import everything when I start a new project and it can get quite complicated/time consuming since I often have multiple source files connected to a bin. Anything you can offer is most appreciated.
    Andre Anthonio replied 14 years ago 2 Members · 2 Replies
  • Edward Troxel
    August 27, 2012 at 3:08 pm
    Open both projects at the same time in two different instances. Drag the bin from one instance to the other instance.
    Edward Troxel
  • Andre Anthonio
    August 27, 2012 at 4:02 pm
    Super thanks for your answer and so swiftly as it worked like a charm. For any newbies out there, “Opening up both projects at the same time” means (in other words) to have both projects open in minimized windows so that you see both project at the same time (same instance). When you can see both projects side-by-side, that’s when you can drag and drop the bins from one to the other.
