Copying Text AND Styling from a ‘Master’ text layer
I need to edit some text but for multiple compositions.
I figured I would try to make a ‘master’ text comp so when and set expressions to follow the master. However when I try do this, it copies the actual text, but not the styling. See examples below attached:
(I also tried to use this expression but does not work)
Any help would be greatly appreciated 🙂
