Activity › Forums › Adobe Premiere Pro › Copying My DVD to Tape, then into Premiere Pro
  • Copying My DVD to Tape, then into Premiere Pro
    Posted by Raymond Tarry on August 1, 2008 at 8:06 pm
    Hello, I’ve got a DVD of my short film that I want to copy into Premiere Pro 1.5 so I can make shome short clips for the web. I think there’s a way to view it on a TV screen, export it to tape into my DVX100A adn then Firewire it back into Premiere Pro.
    Anyone know the procedure/settings to do this? Thanks – Raymond
    Raymond Tarry replied 18 years, 2 months ago 2 Members · 2 Replies
  • Lloyd Coleman
    August 2, 2008 at 2:33 pm
    I am not familiar with the details of the DVX100A, but if the camera has a way to feed the DVD footage from a DVD player (RCA cables to camera, RCA cables to AV plug, etc) and the camera can be used as an analog to digital convertor, then you can play the DVD into the camera and then back out over firewire to the computer and capture as an AVI file. I have done this many times using other camcorders. Be aware that you are still taking a compressed format from the DVD, so the quality of the AVI file will not be the same as the original footage.
    You could also try copying the VOB file directly from the DVD and renaming the extension from .VOB to .MPEG and try bringing that directly into Premiere. I don’t remember how PPro 1.5 handles this. I have had mixed results trying this method.
  • Raymond Tarry
    August 2, 2008 at 4:38 pm
    Thanks Lloyd, I played it through my TV and Firewired it back into my PC. The only momentary snag, was that I didn’t think to remove the DV tape in the camera, so it kept capturing that tape. But when I removed it, it captured the DVD feed. Thanks again, and have a great day – Raymond
