Copying motion atributes issue
Hello,
I have quite an annoying problem with copying of atributes. The situation is following: There was a scene which required some speed tweaking. The take straight from rush, got sliced and the speeds were adjusted (there is quite a lot adjustments in a single slice). However, because the grading had to be done by someone else, at the same time with the edit, now I have to reconnect the graded unedited version with the edited one. Standard reconnecting doesn’t work here. The problem is that even after I sliced the graded version by matching in/out’s copying the edited slice atributes and pasting them to the graded slice gives a very weird result. It appears as FCP disregards all the slicing, and is copying all the keyframes regarding to the edited slices on track to the single graded slice. I hope i explained it clearly enough. . Is there any way I can make FCP copy speed atributes from one slice to another (the graded and ungraded slices with all the atributes removed are different only by colour) which would make the other clip look exactly as i copied the keyframes? It appears as I’ll have to manually redo the whole edit on the graded version mundanely retyping the keyframes. I don’t even know how to ask that question properly, hah. Thanks for any help.
