Activity Forums Apple Final Cut Pro Legacy Copying FCP project on to another drive
  • Copying FCP project on to another drive
    Posted by Guy Crossman on June 7, 2009 at 9:17 am
    I’ve got everything from my FCP Project- media and the project itself, on one external Lacie drive. I would like to copy the whole lot onto another Lacie drive, so that it can be opened on another machine, and worked on for the colour grade and sound dubb- with access to all the original rushes. What do I need to do to ensure that everything is copied safely?
    Guy Crossman replied 17 years, 3 months ago 3 Members · 4 Replies
  • Simon Malcolm
    June 7, 2009 at 11:21 am
    Hi Guy,
    A safe way to ensure you’ve copied everything is to use a free program called Carbon Copy Cloner. You’ll find it at: https://www.bombich.com/software/ccc.html
    There is a provision to donate to the program writer if you wish. I’ve found this to be a great tool.
    Hope this helps,
    Simon Malcolm.
    Simon Malcolm Productions – Helping clients communicate
  • Walter Biscardi
    June 7, 2009 at 12:03 pm
    [guy crossman] “I would like to copy the whole lot onto another Lacie drive, so that it can be opened on another machine, and worked on for the colour grade and sound dubb- with access to all the original rushes. What do I need to do to ensure that everything is copied safely?
    Copy the Final Cut Pro Documents Folder and the FCP Project along with any additional media elements to the new drive.
    Eject and turn off the original drive.
    Open the Project from the new drive and reconnect all the media to that drive. If everything is there, you’re good to go, just save the Project and hand it off for color grade.
    Or
    If your project is completely finished just Media Manage the final Timeline. Use the Copy function to copy all the media in that finished timeline to a new project. That will give the colorist all the necessary raw material for that particular timeline. This is how I usually receive finished projects for color grade.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Guy Crossman
    June 7, 2009 at 3:09 pm
    Thanks I’ll try it
    Guy
  • Guy Crossman
    June 7, 2009 at 3:22 pm
    I’ll try the Media Manager
    Thanks for the advice
    Guy
