Copying Envelop
Posted by Guillaume Jeffrey on March 11, 2011 at 1:08 amIs it possible to copy an envelop for one track to another? Is there any script out there to do that, or only the manual option?
Guillaume Jeffrey replied 15 years, 6 months ago 2 Members · 2 Replies -
Aleksey Tarasov
March 11, 2011 at 10:29 amFrom Vegas help file:
1) Select the Envelope tool.
2) Select the envelope you want to copy:Double-click above the time ruler to create a time selection that matches the length of your project.
Click the envelope you want to copy.
If the envelope isn’t displayed, you can right-click the track, choose Show Envelopes from the shortcut menu, and then choose an envelope from the submenu.3) From the Edit menu, choose Copy.
4) Select the envelope where you want to paste the envelope points:Click within a track to select it.
Insert an audio or video envelope if needed.
Click to select the envelope where you want to paste the selected points.
Click Go to Start if you want the envelope to appear exactly as it was in the original track, or click to position the cursor where you want the envelope to start.5) From the Edit menu, choose Paste.
