Activity › Forums › Adobe After Effects › Copying effect keyframes from one layer to another while keeping settings
  • Copying effect keyframes from one layer to another while keeping settings
    Posted by Al Mach on April 24, 2019 at 4:56 pm
    I’m using the stroke effect to animate a line reveal, so I’ve changed the stroke effect’s default settings on my first layer to “Reveal Original Image” (using my mask), brush size at 4, hardness at 100%. My issue is that I have 100 other layers I want to use this same effect/keyframes on, so I just copied and pasted the keyframes to the other layers. Problem is that the settings within the effect that I changed are not copied over. Is there any way to copy an effect to a new layer to include the new settings I’ve made to that effect? Is there a way to not have to manually change this effect for every other layer manually?
    (I know I could try to use an expression but I also want to control and stagger the reveals, and I’m not very well-versed in expressions.)
    Kalleheikki Kannisto replied 7 years, 5 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    April 24, 2019 at 5:32 pm
    If you copy the effect, everything comes over, settings and key frames included.
    Senior Graphic Designer
