Activity Forums DaVinci Resolve Copying corrections: one track of multi-track timeline
  • Copying corrections: one track of multi-track timeline
    Posted by Craig Mieritz on August 7, 2011 at 3:41 pm
    Is there a way to transfer corrections, including composite modes, on multi-track timelines to an entire track easily? I can do it in the Color page, on a clip by clip basis but can’t find a way to make it work using the Track node graph. Is it possible to use the Track node tab to apply a correction to just one track? If I select a clip from track 2 and apply correction to a node on the track node graph, it seems to apply it to all the clips on all the tracks.
    Craig Mieritz replied 15 years, 1 month ago 1 Member · 2 Replies
  • Craig Mieritz
    August 7, 2011 at 3:45 pm
    I should make a correction. I find that when I apply correction nodes including composite modes on a clip basis, the composite modes seem to only transfer sometimes. Is there something I am doing wrong? I cannot discern a pattern. Any insight is greatly appreciated!
  • Craig Mieritz
    August 7, 2011 at 6:29 pm
    Ah, ok. I see that it seems to be not possible to copy a composite mode, say from a Power Grade. My confusion stemmed from the fact that Base Mem commands clear everything except Composite modes from a clip. The times when I thought that the Power Grade was also transferring a composite mode, the composite mode was already applied that I thought I had cleared with Base Mem. Hopefully this makes sense.
    So, I guess my question really is: is there a way to apply a Composite Mode to one entire track on a multi-track timeline or from a Power Grade? I have tried:
    1. Selecting all the clips on a track in the Conform Page and right clicking and adding the Composite mode
    2. Create a group in the Color page for all the clips in the track and then apply a Composite mode to one of the clips in the Conform page.
    3. Tried a couple of ways in the Track Node Graph to copy it over.
    It’s quite possible I am overlooking something, I am pretty new to DaVinci. It would save a lot of time to if this is possible. Any help is appreciated.
    Thanks-
    Craig
