Activity › Forums › Apple Final Cut Pro › Copying and pasting projects
  • Copying and pasting projects
    Posted by James Ewart on October 3, 2012 at 1:00 pm
    Okay I should have just duplicated the project but anyway I didn’t. selected version 1 and copied it and then pasted into a new project (sequence to me still!) version 2.
    Well in version 2 some shots moved. Connected clips changed their connections especially when they were connected to gaps although the gaps remained and audio level adjustments did not remain as they were in V1.
    Is that a little buggy?
    James Ewart replied 13 years, 12 months ago 2 Members · 2 Replies
  • Oliver Peters
    October 3, 2012 at 2:09 pm
    Weird! Assuming you didn’t inadvertently nudge something, could there have been a difference in project frame rates that might have caused this?
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • James Ewart
    October 3, 2012 at 2:13 pm
    Double weird when I duplicate the project all is well and then as a test I copied the duplicated project into a new project and the problem was not there but when I again copied and pasted v1 the problem was the same again.
    So to reiterate copying and pasting the original project resulted in connected clips that had ben connected to gaps and audio levels misbehaving but duplicating the project and then copying and pasting that was fine!!
    I suppose I could trash the render files and re render.
    Having trouble with stuttery H264 exports now…this software is buggy!!
