Activity Forums Apple Final Cut Pro Copying all clips between an and out point in a project
  • Copying all clips between an and out point in a project
    Posted by Tom Fox on April 12, 2013 at 4:04 pm
    It should be simple, but I can’t figure it out.
    I just want to copy all clips between an and out point (not just the ones on the primary storyline) and paste them into another project.
    What’s the trick?
    T
    James Cude replied 13 years, 4 months ago 2 Members · 1 Reply
  • James Cude
    April 12, 2013 at 8:25 pm
    You can’t do that precisely- what you can do is draw a lasso around the clips you want to copy. You may end up with an overlap of some clips you don’t want outside of the in/out range but you can easily delete these once you copy/paste to the other project.
