Activity › Forums › Apple Final Cut Pro Legacy › Copying a dissolve to multiple edit points?
  • Copying a dissolve to multiple edit points?
    Posted by Chris Ward on April 21, 2009 at 6:58 am
    Hi there crew.. I’m putting together a photograph stills video (similar to stop motion I guess) which is made up of about 750+ photos. Just wondering if there’s anyway of selecting all of the edit points and applying a 3 frame dissolve to each with the click of a button?!
    Any feedback is welcome..!
    Cheers
    Chris
    Chris Ward replied 17 years, 5 months ago 2 Members · 2 Replies
  • Dennis Leppell
    April 21, 2009 at 7:50 pm
    set your dissolve as the default transition.
    next, drag your clips/photos to the canvas and drop it on the insert with transition droplet. There’s probably a keyboard button you could hit to do it quicker, but I don’t know it offhand. If there isn’t, I’m sure you could set it up.
  • Chris Ward
    April 22, 2009 at 7:00 am
    Dennis, thanks for the tip. I thought it might be that easy!
