Activity Forums VEGAS Pro Copy track effects to clip
  • Copy track effects to clip
    Posted by Bruce Quayle on January 26, 2011 at 1:58 am
    Hi All,
    I have spent a great amount of time adding a number of video effects to a track on which I have a graphic…only to discover that the effects and key-frames cleverly remain just where I programmed them…on the track…not on the clip where I wanted them in the first place.
    Is there any way I can copy these effects and key-frames from the track and paste them on my clip?
    Thanks for helping me correct my stupid mistake.
    Cheers,
    Bruce
    Bruce Quayle replied 15 years, 8 months ago 3 Members · 4 Replies
  • John Rofrano
    January 26, 2011 at 2:11 am
    You can save the FX chain on the Track as a Filter Package. Then apply it to the Event. This should save and restore all of the keyframes too.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Bruce Quayle
    January 26, 2011 at 2:26 am
    Thanks John…you’re a star!
    Cheers,
    Bruce
  • Danny Hays
    January 26, 2011 at 2:34 am
    Cool John. Another great tip. Thanks
  • Bruce Quayle
    January 26, 2011 at 4:07 am
    Okay guys…I’ve been doing a bunch of tests on this and here is what happens when you save the filter package from the timeline:
    1) Saves all the filters you have added in the correct order.
    2) Saves all your settings.
    3) Saves all the key frames.
    But there is a catch!!!
    It also saves the first key frame on the timeline – the one at the very start. And this key frame obviously doesn’t have the correct settings of “your” first key frame.
    So once you have added your saved filter package to your clip, you need to delete the first key frame of each effect and slide “your” key frames back to the start of the timeline of your clip.
    If however, you save a filter package from a clip, it will simply remember the start and end key frames and put these at the beginning and end of whatever length clip to which you add them.
    Hope this is relatively clear.
    Bottom line is it works great and thanks again to John for pointing me in the right direction.
    Cheers,
    Bruce
