Activity Forums Adobe After Effects Expressions Copy selected property to a Null Layer's Position
  • Copy selected property to a Null Layer's Position
    Posted by Kevin Snyder on September 6, 2021 at 8:24 pm
    I’m trying to write a script that will copy keyframes from a selected property to the position property of a new null. For example, in the image below I want to select Point1 keyframes from the Lockdown effect and have them copied to a null layer’s position with the name “Point1”.
    I am having a tough time getting the script to paste just the keyframes to the position value of the null instead of pasting the entire Lockdown effect.
    I have disabled the naming part of the script…can’t get it to work.
    app.beginUndoGroup("Copy to Null");
    app.executeCommand(19); //copy
    var controller = app.project.activeItem.layers.addNull(); //Create null
    //myProp = app.project.item[0].layer[0].selectedProperties.name; //Selected property name
    controller.name = "myProp"; //Name null
    controller.enabled = true;
    nullLayer.property("position");
    app.executeCommand(20); //paste
    app.endUndoGroup();
    Kevin Snyder replied 4 years, 11 months ago 2 Members · 7 Replies
  • 7 Replies
  • Fabrice Leconte
    September 6, 2021 at 11:43 pm
    Hello, maybe something like this:
    app.beginUndoGroup('Copy to Null');
    controller.name = 'myProp';
    controller.property('position').selected = true;
    app.endUndoGroup();
  • Kevin Snyder
    September 7, 2021 at 3:36 am
    Yes! That’s working. Thank you. Is there any way to name the null layer based on the selected property and also have it create a null for each point selected so that there is a null titled “Point1”, “Point2” and so on depending on what’s selected?
  • Fabrice Leconte
    September 7, 2021 at 2:00 pm
    It should work.
    function createNulls() {
    var sLayers = thisComp.selectedLayers;
    if (!sLayers.length) {
    alert('Please, select a layer');
    return false;
    var sProperties = thisComp.selectedLayers[0].selectedProperties;
    if (!sProperties.length || sProperties.length < 2) {
    alert('Please, select at least 1 property');
    return false
    for (var i = 0; i < sProperties.length; i++) {
    var sProperty = sProperties[i];
    if (sProperty.numProperties == 2) {
    var myNull = thisComp.layers.addNull();
    myNull.name = sProperty.name;
    myNull.transform.position.expression = 'thisComp.layer("' + sLayers[0].name + '").effect("' + sProperty.name + '")(1)';
    myNull.transform.position.selected = true;
    // OPTIONAL
    // app.executeCommand(2639); // Convert Expression to Keyframes
    // myNull.transform.position.expression = ''; // Remove the Expression
    app.endUndoGroup();
    var thisComp = app.project.activeItem;
    createNulls();
  • Kevin Snyder
    September 7, 2021 at 5:01 pm
    Thank you! I gave it a go but it’s not working. If I select a layer and the position property I get a message stating that I need to select at least one property and when I select the keyframes from the Lockdown plugin nothing happens.
  • Fabrice Leconte
    September 8, 2021 at 3:42 am
    For Lockdown use this code:
    return false;
    return false
    if (sProperty.name.match(/Point[1-4]/)) {
    myNull.transform.position.expression = 'thisComp.layer("' + sLayers[0].name + '").effect("Lockdown")("' + sProperty.name + '")';
    // OPTIONAL
    // myNull.transform.position.selected = true;
    app.endUndoGroup();
    createNulls();
  • Kevin Snyder
    September 8, 2021 at 3:26 pm
    Perfect. Thank you for your help. I really appreciate it.
  • Kevin Snyder
    September 21, 2021 at 4:05 am
    Fabrice Leconte,
    Are you available for hire? I have some ideas for some scripts that I would like to hire you to build if you’re interested.
