Activity › Forums › Apple Final Cut Pro Legacy › copy portion of media used on timeline
Posted by Jason Brown on August 27, 2010 at 7:11 pmI’m going to kick myself because I’m sure I know how to do this…
I have a clip 10minutes of footage recorded as one clip.
I have used about 9 seconds of that clip…and I want to create a brand new clip based only on the portion of the original clip used.
I’ve been playing in Media manager, and it is taking a MUCH larger portion of the clip than I’m wanting…
-Jason
Jason Brown replied 16 years ago 3 Members · 8 Replies -
Shane Ross
August 27, 2010 at 7:12 pmDid you check the DELETE UNUSED? Does the clip have a REEL number?
Shane
Read my blog, Little Frog in High Def -
Jason Brown
August 27, 2010 at 7:55 pmDelete unused checked.
No REEL number….added one, and BLAM…shane, you are a genius. Thanks so much.
No REEL because it came from a live recording into none other than my MXO2 🙂
Thanks, I can figure out the rest…
-Jason -
Shane Ross
August 27, 2010 at 8:03 pmLive recording, no matter what device you use (Same thing would happen if you used your Kona LHi), doesn’t automatically assign a reel number. You have to remember to do that yourself, or do it afterwards.
Shane
Jason Brown
August 27, 2010 at 8:16 pmI actually didn’t record it…but just curious, what do you use as a Reel? I made a notation that it was a live recording and what device was used…
Shane Ross
August 27, 2010 at 8:45 pmIf there is no actual tape, then ANYTHING will do. What you did was good.
Shane
Matthew Bradshaw
August 27, 2010 at 8:58 pmI’m probably reading this wrong but why don’t you just mark in and out on the used portion of the clip and export it?
Matt. -
Jason Brown
August 27, 2010 at 9:51 pmI guess that was an option, I’ slime to pick ur guys brains about this, cause I don’t understand reconnecting or media manager very well.
My process (which worked) was to select the clip in the timeline (multiple selections) and media manage…select copy, delete unused with 1 sec handles…it created new media. I then right click on clip (linked with audio) and “make independent clip”, then match frame to source…not one in browser, so I create new one…right click, reconnect to the new media. I dd this for all clips I copied. I closed fcp to remove drive where original clips were, relaunched…and video was good…but audio was offline.
Where did I go wrong?
Jason Brown
August 27, 2010 at 9:54 pmBtw…I don’t want to “slime” anyone! 🙂
I’m on mobile and it autocorrected…
Also, wanted to mention that all I had to do was reconnect audio to the new clip and everything worked fine. It’s all good now, just curious what happened.
