Activity › Forums › Adobe After Effects › Copy & pasting keyframe data without replacing interpolation
  • Copy & pasting keyframe data without replacing interpolation
    Posted by Christof Van niekerk on June 4, 2019 at 3:54 pm
    I have a 3d objects with a numerous keyframes on “position” property…. their interpolations have been
    finely tuned to my liking in the graph editor already.
    Some clients changes now require that I copy keyframe data from one key (XYZ) to another without losing the interpolation I’ve already tweaked.
    So 2 questions:
    1 – how do i copy the values XYZ (every time I select the PROPERY it selects ALL the keyframes…. or if I select the single keyframe to copy, it obviously selects the interpolation data too)
    2 – how do I paste it whilst leaving existing interpolation intact
    This feels like I’m missing something super obvious… so thanks a bunch in advance for any help
    Christof Van niekerk replied 7 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Richard Garabedain
    June 5, 2019 at 9:44 pm
    have you heard of parenting? this should solve all your woes…Are you new to after effects?
  • Christof Van niekerk
    June 6, 2019 at 12:10 am
    Not new to AE – but maybe I’m explaining my problem poorly.
    So perhaps this is simpler:
    June 6, 2019 at 12:17 am
  • Kalleheikki Kannisto
    June 8, 2019 at 7:58 am
    Sounds like you need to copy the values, not the keyframes. So that’s three copy-paste actions, X, Y and Z individually.
    Senior Graphic Designer
    June 8, 2019 at 9:10 am
    Ok, thanks.
    Was really hoping there was an easier (quicker) way. I found I need this pretty frequently.
    And the 3 separate value copy-paste actions each time was getting so annoying.
    In most 3d packages one can just highlight the XYZ values, copy, and then paste in one go.
    But thanks for your help. Needed confirmation for my own sanity 😉
    June 9, 2019 at 4:00 pm
    If you need to do this a lot, maybe something like this, then?
    https://aescripts.com/easecopy/
    June 10, 2019 at 11:52 am
    Thanks a bunch for the suggestion – definitely checking it out!
