Activity Forums Adobe After Effects copy & paste the effect information (after effect cs4)
  • copy & paste the effect information (after effect cs4)
    Posted by Mayuko Yoshida on November 11, 2010 at 1:10 am
    Hi, I want to copy & paste the effect information.
    How can I do that? I want to replace the image that already has the effect ( position, scale, etc information ) with another image.
    Paul Minnaar replied 15 years, 9 months ago 3 Members · 3 Replies
  • Paul Minnaar
    November 11, 2010 at 1:39 pm
    When in the layer with all the effects, press F3 to bring up the effects panel. Select all, ctrl+C and then select the target layer, press F3 and paste (ctrl+V) into the new layer.
    Should work
  • Walter Soyka
    November 11, 2010 at 2:00 pm
    [Mayuko Yoshida] “Hi, I want to copy & paste the effect information.
    How can I do that? I want to replace the image that already has the effect ( position, scale, etc information ) with another image.”
    No need to copy and paste if you want to replace the contents of a layer with another piece of footage. From the AE help on imported files and footage items:
    To replace the source footage item for a layer with another footage item, without affecting changes made to the layer properties, select the layer and then Alt-drag (Windows) or Option-drag (Mac OS) the new footage item onto the layer in the Timeline panel.
    Walter Soyka
  • Paul Minnaar
    November 12, 2010 at 6:30 am
    Whoooops my bad. I did not interpret the question correctly. Walter is 100% correct, just replace footage. pretty easy, I thought you wanted to apply the effects to another layer in the comp.
