Activity › Forums › VEGAS Pro › Copy into other instance.
  • Copy into other instance.
    Posted by Roger Bansemer on February 24, 2010 at 5:41 pm
    I have two instances of Vegas 9 open. I wanted to copy several clips from Vegas 64 bit to Vegas 32 bit so I could edit with a plug-in (which won’t work with 64 bit) then render it and put it back into Vegas 64 bit to continue.
    I can copy but the paste even though not grayed out in 32 bit, does not paste.
    I could just open the clips without copying but wondered if I am missing something with the copy/paste.
    Thanks as always.
    Jeremy Rasnic replied 16 years, 7 months ago 2 Members · 2 Replies
  • Jeremy Rasnic
    February 24, 2010 at 8:57 pm
    I don’t think you are missing anything with copy/paste; however, I would say that you can merely open your project in Vegas 32 and make the adjustments there and render the files with the fx you want and then open it back up in 64 bit Vegas Pro.
    That should be quicker for you.
    j razz
    https://www.jrazzcreations.com
  • Jeremy Rasnic
    j razz
