Activity › Forums › Adobe After Effects › Copy Comp Settings Shortcut
  • Copy Comp Settings Shortcut
    Posted by S. Marcotte on February 24, 2009 at 7:06 pm
    Is there a shortcut key that let’s me copy comp settings from one comp to another? (like the “Ctrl+Alt+V” for Apply Interpretation.)
    S. Marcotte replied 17 years, 7 months ago 2 Members · 2 Replies
  • Kevin Camp
    February 24, 2009 at 7:29 pm
    not that i know of, but there is a script that will do something similar called ‘selected comps changer’. you can download it from crgreen.com/aescripts/.
    make sure it keeps the .jsx tag after download. then install it in adobe after effects>scripts folder. restart ae and it will show up in file>scripts. just select a bunch of comps, run the script, then set the comp settings…. each selected comp will take on the new settings.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • S. Marcotte
    February 25, 2009 at 12:11 am
    Thanks very much. Will try. Lot of stuff to look at on this page.
