Activity Forums VEGAS Pro Copy and Paste
  • Copy and Paste
    Posted by Roger Bansemer on January 18, 2013 at 1:03 pm
    This is strange.
    If I have a video event that is muted (usually because I have used multi-track)and then I copy that event to use it in another project, the event is still muted.
    That would seem OK except when I look at “properties” the “mute” box is not checked indicating that it should be viewable and there doesn’t seem to be any way of making it visible in the preview.
    The only way to bring it back is to drag it on the timeline anew from explorer.
    Roger Bansemer replied 13 years, 7 months ago 3 Members · 3 Replies
  • Steve Rhoden
    January 18, 2013 at 2:09 pm
    Did you check in options if Mute All Video was selected?
    Also after you copied the event and its still muted, did it
    have somewhat of a shade over it?
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-832-4956
  • John Rofrano
    January 19, 2013 at 11:54 am
    This could be a bug. I would unmute it in the original project before you copy it into the new one. Alternately, check the mute button and close the properties dialog, then open it again and uncheck the mute button to try and get it to toggle.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Roger Bansemer
    January 20, 2013 at 2:13 am
    I’ll give that a try. Thanks.
