Activity › Forums › Apple Final Cut Pro Legacy › Copied sequence not updating
  • Copied sequence not updating
    Posted by Simon_p_m on August 2, 2006 at 8:37 am
    I’ve come across an intermittent problem in FC5, which is driving me nuts.
    I create a complex sequence (let’s call it Sequence A), copy it, and paste it into Sequence B. To begin with, I’m able to make changes in Sequence A, and see them automatically update in Sequence B. However, after a while, any updates in A aren’t carried across to B.
    Any ideas what’s stopping the updates?
    Bob Flood replied 20 years, 1 month ago 2 Members · 1 Reply
  • Bob Flood
    August 10, 2006 at 6:46 pm
    hey
    welcome to the confusing realm of nested timlines
    I do not know how or why or when the link between the timeline A on the canvas and the timeline A in your timeline B gets broken, but it does. (maybe its when you open timline b out of the browser) you can do various things to each timeline, anf the other will never change
    its very frustrating as its not consistent
    what i do, as a solution, is ALWAYS double click on my Timeline A thats in my TImeline B. this will open it up in the canvas and allow you to modify it and those mods will show in your timeline B.
    The other thing you can do, which is a little more time consuming but makes the connection rock solid, is export timeline A as a native QT, Import it back in, and cut it into timeline B. each time you need to change timeline A, simply re export again, overwriting the previous export so the name stays the same, and fcp will reconnect to the file!
    hope this helps
    bee eph
